Mygamertagsucks
Feb 24, 2022Apprentice
Game Disconnected- Weird Log Files
Hi, again I'll keep this short. I was playing CoD Vanguard on my PlayStation, and around 10:10pm Eastern Daylight Time, I could not find a match. I closed the app, and restarted it, and when I clicke...
- Feb 25, 2022
There's nothing too telling in those log files unfortunately. How's your Geo-filter currently setup?
If you disable filtering mode, do you then get into a game straight away?
Netduma-Liam
Feb 25, 2022NetDuma Partner
Mygamertagsucks
Feb 25, 2022Apprentice
Oh my gosh. I can't believe I didn't put two and two together. All of this started right after I took the tour of the new Geo-Filter screen, and read everything that popped up. I know/knew how to use the Geo-Filter, before, but something was different this time. The circle, while present (before I took the tour), failed to show any server locations, and failed to display any server information. I didn't know if that was a Netgear and Netduma issue, or a call of duty issue. I gave up after power cycling everything, and rebuilding the PS4 database, because the problem persisted. I'll turn off the filtering tonight, and see if that fixes things.
Thank you for always being so prompt, and always being here to lend a helping hand. This is one of the few forums where everyone remains civil to each other, and I appreciate it.
- MygamertagsucksFeb 25, 2022ApprenticeOut of curiosity, if a second PS4 were to hop on our network, while I'm playing multiplayer, would this be enough to cause the issues I had? I ask because my Dad picked himself up a PS4 for some reason, and even though he never, ever plays any multiplayer games, he always leaves his console in rest mode, instead of turning it off. I turned his off last night before I turned mine on, since he wasn't using it, but I have a feeling when he went upstairs, he turned it back on.
I may just be grasping at straws here. I still haven't had a chance to try to apply the fix to the Geo-Filter, but I will let you know just as soon as I get home and am able to give it a try.
Thanks, again. I'm sure you guys are getting tired of me always posting some random arse, bizarre problem that I'm having.- Netduma-FraserFeb 25, 2022NetDuma PartnerIf it is always online then it's highly likely downloading updates for the console and games in the background and if that coincides with you playing then yes it could potentially cause some lag for you. Not at all, we're here to help!
- MygamertagsucksFeb 25, 2022ApprenticeSo, I have an update to my Geo-Filter problem, but still have a question about my Geo-Filter. When I turned off the filtering mode, I was once again able to get into matches. However, my circle is still missing, so I can not set a limit as to how far away is acceptable. I've used the polygon mode, and hate it. But, I may have to use it I guess.
