Fadii
May 10, 2022Guide
Game lag xr700
Hi, I have a nighthawk xr700 which is configured with QoS and game traffic prioritization (by port). when i am playing warzone on my ps5 and the apple tv is playing at the same time, the game bec...
Fadii
May 13, 2022Guide
Hi
download speed tests show that i have 600Mbps for download and 95 Mbps for upload.
i have set the download speed on my router to 350 Mbps, and upload at 85 Mbps (not exactly matching the actual test values, leaving some room in the bandwidth).
I have set the anti-bufferbloat to 70% for both download and upload. (when high priority traffic detected).
QoS for ps5 is set at 30%. Share excess option is deselected.
Netduma-Liam
May 13, 2022NetDuma Partner
I'd suggest setting your speeds in DumaOS a little more accurately than this, closer to 600.
Presumably the Apple TV is also connected directly to the XR700, yes?
If that's the case, could you please try disabling all rules in Traffic Prio and create a new one for the PS5. Select 'Games Console' when prompted to select a service.
Let us know if that works better.
- FadiiMay 13, 2022Guide
i have attached a screen shot of the rules i have. i only have ps5 rules which are set to console.
if i delete them i have to create them again. (p.s. i only created the rules 10 days ago after I started experiencing lags.
regarding the connectivity: Apple TV <--> TP link router <--> XR700... All connections are via ethernet.
- Netduma-LiamMay 13, 2022NetDuma Partner
OK you don't need to disable the rules from before, just disable them. Then add the new one as I mentioned.
Are all devices on the network connected to the XR700 or do some devices still connect to the TP Link you mention?
- FadiiMay 14, 2022Guide
hi
I removed all the rules.
I created a rule for ps5 as a gaming console in trafffic prioritization section,
apple TV is on, game still lags. If i turn it off. game stops lagging.
Hi again,
i set the bandwidth values close to actuals. i dont have much utilization on the network and the game still starts lagging all of a sudden.
I am wondering if i need to change the image on the router, would that help?
regards,
