Raidrew
Jan 21, 2019Aspirant
Gaming lag and drops
Hello,
I buyed a new XR500 router to have better performances with my working Mac (I upload a lot of material and I'm far from the wifi station) and my PS4 (I experienced some minor lag, someti...
Raidrew
Jan 22, 2019Aspirant
I have the basic Telecom router, with a speed of 60mbps download and 20mbps upload.
I can't use my PS4 wired, I'm 6-7 meters away from the router, in another room.
The sad thing is that, as I said, yesterday I tried with my old 2013 Buffalo router and I have no issue at all.
I haven't the time to test if it was the QoS.
michaelkenward
Jan 23, 2019Guru - Experienced User
That is not a make and model number, as requested by FURRYe38.
If it really is, as you say, a router, and not just a modem, that will complicate the issue.
- RaidrewJan 23, 2019Aspirant
Yeah it's a router that my ISP give me. I disabled the wifi network and disabled the firewall.
As I said, the strange thing is that my other router works fine attached to the same modem + router :\
I will share more info soon.
If I need to buy a modem, wich one would be the best to work with the XR500?
- michaelkenwardJan 23, 2019Guru - Experienced UserDisabling the WiFi and the firewall (if that is possible) does not disable the router.
- FURRYe38Jan 23, 2019Guru - Experienced User
A modem with out a built in router would be preferred.
Any broadcom based modem is also preferred.
The advantages of that are not just that it is easier to configure a basic modem but that they are inexpensive.
We don't know what internet service you have, but for DSL I have the Netgear DM200. Inexpensive and fast to start up. In the past I have had a modem that took so long that the router beat it to it, and failed to get a connection.
Any make would probably be fine, but it can be easier to stick with one maker. You then get familiar with the graphical user interface (GUI) and, should you need it, you can get all the help you need in one place!
- Netduma_JackJan 23, 2019NetDuma Partner
Most modems work fine, just avoid a modem with a Puma 6 chipset! https://www.classactionlawyers.com/puma6/
