carlh1
Aug 15, 2019Initiate
Gaming Router on Mesh - XRM570 Nighthawk Pro Gaming WiFi Router and Mesh WiFi System with DumaOS
I currently have an older nighthawk and have been happy with it. however, i have a 2500 sq foot two story and it's not reaching everywhere i would like. I did an older extender to the garage and one...
carlh1
What i means is if i can do more than one mesh repeater with that XRM570, or with another nighthawk/repeater setup? I'm on the never ending search for speed and power :-)
Netduma-Fraser
Aug 15, 2019NetDuma Partner
As far as I am aware you should be able to connect multiple extenders to the router to create a mesh system. You could also connect your existing netgear router and put it in AP mode to extend wifi range as well.
