JonSnowKnowsNad
Apr 12, 2020Apprentice
Gateway and XR500 setup help
Gateway (disable Wifi) ---> S8000 managed switch ---> XR500 (AP mode) SO this is a setup a youtuber called John Glasscock recommended in his video "Turn Your ISP Router into a Gaming Router." He re...
Netduma-Fraser
Apr 14, 2020NetDuma Partner
That's right, in AP mode you will not have any of the XR500 features. You would be able to put it in router mode yes. I wouldn't recommend this setup however as you're not able to use QoS effectively to control all devices and therefore limit local congestion. You would still be able to use the Geo-Filter if the device was plugged into the XR in this setup if you wanted to keep it this way.
- JonSnowKnowsNadApr 14, 2020Apprentice
lets say I have all the devices connected to my xr in router mode. then i would be able to QoS effectively. I think the youtuber recommends i put the router in AP mode because it prevents double NAT issues or something like that im not sure if that's true could you confirm that. Plus my switch has QoS so i wouldnt need the xr QoS in this setup. i would plug in devices to my switch that i would give high priority like my ps4 and my pc and then give my xr low priority.
- Netduma-FraserApr 14, 2020NetDuma PartnerIt would prevent a double NAT but that's not why people use that feature. Using the DMZ would fix it while keeping it in router mode. If the PS4 is connected to the Switch above the XR then you wouldn't be able to use the Geo-Filter either, that's why I'd suggest Gateway > XR > Switch
yeah, but im not familiar with DMZ and the geo-filter from my experience has its negatives so im not worried about getting to use that feature.
