henry85
Dec 14, 2018Aspirant
Gateway Wifi Router to monitor wireless temperature sensor and send data to Azure Iot hub
I want to send wireless pressure sensor data to azure IOT hub. For communiction between wireless sensor and Internet, I am looking for gateway Wifi router which can act as access point as well as sta...
Dec 15, 2018Guru - Experienced User
Are you looking for a modem with a built in router?
henry85
Dec 17, 2018Aspirant
Hey, Thanks for the reply
Yes, I am looking for the modem with IEEE 802.15.4 standard built-in with the router
Does The router You have mentioned use the XBEE devices?
Or should I have to use connect Receiver modem with this kind of router to receive the value?
