MrDsg44
Dec 11, 2019Aspirant
Geo-filter error: "Uncaught undefined"
Whenever I try to use the Geo-Filter on my router it just loads/thinks for a while and then I get a small partially broken up window saying: "Uncaught undefined". Any knowhow regarding that? :) Be...
Netduma_Alex
Dec 12, 2019NetDuma Partner
I believe that this might be to do with a device that was previously in the Geo-Filter but was moved.
As a test, could you try using an Incognito or Private window in your browser and doing the same thing? This will eliminate the possibility of it being a caching problem.
- MrDsg44Dec 12, 2019Aspirant
Hey, thank you for the reply.
I tried doing as you asked but had exactly the same issue. Maybe I also should add that this XR300 is spanking brand new, got it a couple of days ago.
- Netduma-FraserDec 12, 2019NetDuma PartnerSince you've got the router and added the device to the Geo-Filter have you done a reboot or upgrade or anything like that? This happens when the device is no longer there or occassionally if the name has changed. This can be resolved by either renaming the device back to what it was called when it was added to the Geo-Filter or a factory reset will definitely fix it.
Hmm I have not literaly added a device to the Geo-filter. Is that done elsewhere in the DumaOS?
Since the router is new for me: All I did was starting it, installing using the quickstart guide and it updated once for new firmware. I have restarted it once or twice I think. I'll look into your reply and see if it works, thanks :)
