jesusm07
Sep 09, 2018Guide
GEO-FILTER FILTERING NOT WORKING
When I am playing Call of Duty and I set the Geo-Filter to Strict Mode and Filtering Mode it doesn't always block players or servers outside of my set filter range. Sometimes it does and sometimes it...
Netduma-Fraser
Sep 09, 2018NetDuma Partner
Can you include a screenshot of the entire Geo-filter page please when it doesn’t block outside your radius.
jesusm07
Sep 09, 2018Guide
Sure. Included is a screenshot of a middle of a game I played where I had my options on "strict mode". In this particular game the server was within my radius but as you can see players outside of my radius were able to join. I've also had problems where I am connected to servers outside of my radius just as this players are in my game lobby when they should not have been able to.
- Netduma_JackSep 10, 2018NetDuma Partner
The Geo-Filter can't block other players from connecting to a host or server - that would be really unfair for anyone trying to join games, and isn't actually possible either.
The aim of the Geo-Filter is to get you the best host / server possible. This will dramatically improve your ping and gameplay despite the connection quality of other players who join.
I hope this helps!
- XRaptor29Sep 10, 2018LuminaryHalo Master Chief Collection also does this. After a few games I realized I was being connected to th closest dedicated server and all the peer to peer connections I was seeing were players connected to the same server playing the game I was in.
Exactly yeh - the peer 'person' icons you see on the map are other players when you're already connected to a lobby.
If you're playing a matchmaking game like Call of Duty, and you search for a game, there might be multiple peer icons that appear. That's because it's a peer-to-peer matchmaking game, and the peers themselves can be the host.
Your Geo-Filter will block any hosts outside the radius if you have strict mode enabled. Once you're then connected to that high quality host, other players will join as well from anywhere - you'll see players outside the radius as well as inside.
I hope this helps!
