jesusm07
Sep 09, 2018Guide
GEO-FILTER FILTERING NOT WORKING
When I am playing Call of Duty and I set the Geo-Filter to Strict Mode and Filtering Mode it doesn't always block players or servers outside of my set filter range. Sometimes it does and sometimes it...
mncomputerguy
Sep 11, 2018Tutor
I think I know what the problem is, I just bought an xr500 (a buddy of mine had one and it worked fine for the last week or so since he got it). During the initial setup it upgraded the firmware to 2.3.2.32 and speeds were terrible, enabling geo filtering would knock my xbox offline, clicking on players/servers would not show ping etc. Found out his router was on 2.3.2.22, I downgraded mine to that and did a factory reset to clear out any settings and its been working fine for the last 2 days.
2.3.2.32 appears to be a buggy firmware, I would check and see if you have it and go back to 2.3.2.22 if you do, it fixed all my problems.
jesusm07
Sep 12, 2018Guide
thank you for that information. Will check to see what firmware I am running.
