josephquake
Feb 14, 2021Tutor
geo filter i have problems
How can I filter the games only by ping 20 as an example. I have had the problem that connects me with games with ping 60 I only want to play with people from my country only even though I have a geo...
- Feb 15, 2021josephquake I have replied to your topic on the matter.
josephquake
Feb 15, 2021Tutor
That was not to find games outside the selected geographic range. I tried it in warzone but it didn't work for me. I'll see if it works for me in cold wars. I am tired of blocking servers that I do not like their ping, they should solve this is very annoying apparently a 60 ping was within its acceptable range so it puts me on those servers not if you are a developer but I ask you to request something to be able to choose ping that one finds it acceptable in the game since call of duty is a low ping netcode game does not compare you the shots without a good ping to play.
I can not block servers in real time because it takes too long to show me the information that is a serious problem
eso no era para encontrar partidas fuera del rango geografico seleccionado lo intente en warzone pero no me funciono eso vere si me funciona en cold wars. estoy cansado de bloquear servidores que no me gustan sus ping deberian solucionar esto es muy molesto al parecer estuviera dentro de su rango aceptable un ping 60 por eso me pone en esos servidores no si eres un desarollador pero te pido que solicites algo para poder elegir ping que uno lo encuentra aceptable en el juego ya que call of duty es un juego de netcode de ping bajo no te compara los disparos sin un buen ping para jugar
tampoco puedo bloquear servidores en tiempo real porque tarda demasiado en mostrarme la informacion eso es un grave problema
Netduma-Fraser
Feb 15, 2021NetDuma Partner
