Mark9816
Aug 09, 2020Apprentice
Geo filter issue on XR500
I cant get the router to select an allowed server any more when I pick one it just sits there and will not show the servers and then it just picks its own when a game starts even know I had one set i...
- Aug 11, 2020Type DIR and press enter, that will show you what the available folders are where you are - sort of like a simplistic view of the file manager. So then change directories by typing cd and then the name. So I'll give you an example:
You open command prompt and it starts with:
C:\Users\Mark9816> DIR
Results come back as
Folder 1
Folder 2 etc
You know Desktop is located in Folder 2 so type
cd Folder 2
cd desktop
Then continue with the instructions.
Netduma-Fraser
Aug 10, 2020NetDuma Partner
Okay so the servers are being caught by Ping Assist which seems to be overriding so would suggest you put that to 0 (when the game is completely off) and then it should adhere to your radius more. Also please try using Firefox rather than Edge please.
Mark9816
Aug 10, 2020Apprentice
Thank you for the info I will give this a try..
