Mark9816
Aug 09, 2020Apprentice
Geo filter issue on XR500
I cant get the router to select an allowed server any more when I pick one it just sits there and will not show the servers and then it just picks its own when a game starts even know I had one set i...
- Aug 11, 2020Type DIR and press enter, that will show you what the available folders are where you are - sort of like a simplistic view of the file manager. So then change directories by typing cd and then the name. So I'll give you an example:
You open command prompt and it starts with:
C:\Users\Mark9816> DIR
Results come back as
Folder 1
Folder 2 etc
You know Desktop is located in Folder 2 so type
cd Folder 2
cd desktop
Then continue with the instructions.
