JoeFI's avatar
JoeFI
Apprentice
Apr 23, 2021
Geo filter not pinging
Hi, my router was showing 2 devices with same IP address for my ps5 so I did a factory reset today. Reset my geo filter but now it can't find servers when filtering cod warzone and cold war. It does p...
  • Netduma-Fraser's avatar
    Apr 23, 2021
    Try this please:
    Hard turn off the console
    Remove device from Geo-Filter
    Re-sync cloud from Geo-Filter Map menu (if you get a too long message, wait 1 minute then refresh the page and it will have applied)
    Re-add the device to the Geo-Filter
    Setup the Geo-Filter and put Ping Assist to 0
    Wait 2 minutes
    Boot up the game
