Stevecook
Nov 15, 2019Apprentice
Geo filter not showing ping.
My geo filter does not show my ping in game. I have it set to auto ping. One shows ping maybe 1 out of 20 matches but 99 % of the time it doesnt.
Netduma-Fraser
Nov 17, 2019NetDuma Partner
Okay thanks for the information, could you check manual ping please and see if it pings that way?
Stevecook
Nov 18, 2019Apprentice
Manual ping works majority of the time. But also have to set my geo filter to spectating to find a match. If I have on filtering it doesnt find a match. All this started when the new update came out. I've tried deleting console from devices and flushing cloud and restarting ps4 and router none of that works. It sucks because ping isn't working and filtering not working. So have to put on spectate and it puts me in lobbies not near my location and I can not even see what my ping is for that game.
Is there another router that has the Duma software. This router seems like it has several bugs since its release. Has had issues where it randomly drops internet when I first got it. Seems like that has been ironed out now this.
- Netduma-FraserNov 19, 2019NetDuma PartnerCould you provide a full screenshot of the entire Geo-Filter page please so I can see how you've added the device and what settings you're using please?
Routers that have DumaOS are:
Netduma R1/XR300/XR450/XR500/XR700- StevecookNov 24, 2019Apprentice
- StevecookNov 24, 2019ApprenticeHere is setup
- Netduma-FraserNov 27, 2019NetDuma PartnerDefinitely shouldn't be a problem getting a game with those settings but could you change the distance to 650miles instead? Thats our generally recommended minimum distance.
