Stevecook
Nov 15, 2019Apprentice
Geo filter not showing ping.
My geo filter does not show my ping in game. I have it set to auto ping. One shows ping maybe 1 out of 20 matches but 99 % of the time it doesnt.
Netduma-Fraser
Jul 18, 2020NetDuma Partner
Can you see servers? If so does it work when you manually ping the servers? Auto Pinging not work is something we are looking into as it's likely a bug to be fixed.
Crawlers
Sep 21, 2020Aspirant
Same problem here. I did not have this problem on my R1 router, and both autoping and manual ping to any server worked fine. However, now after installing the xr700 the ping number is gone. It used to be placed at the top and also in the graphs. If I push the info button on that panel, the ping is mentioned there, so I guess it stil should be in the panel. I have tried the 7 steps mentioned above in the post. Did not do any thing. Im on version .20
- Netduma-FraserSep 22, 2020NetDuma PartnerDoes it ping properly to other games at all? Also upgrade to this firmware https://kb.netgear.com/000061714/XR700-Firmware-Version-1-0-1-24-Hot-Fix
