Redv
May 22, 2020Follower
Geo filter not showing servers
Gday I recently purchased the xr500 router. I have completed the set up and know need help with the Geo filter not showing any servers. I have a wired connection from modem to xr500. The xr500 is then connected to Tp link Av600 extender by wired connection. The Tp link av600 extender is then plugged into the PlayStation 4 Pro by Ethernet all cables are Cat 6. The connection works fine but is not showing on the Geo filter. Thanks in advance for any help.
1 Reply
- Netduma-FraserNetDuma PartnerTurn off the console fully then remove the device from the Geo-Filter. Then flush the cloud from the Geo-Filter Map and then re-add the device and turn on the console. Does it work correctly then?
