Humboldtk20
Jan 19, 2023Aspirant
Geo-filter question xr1000
I have an XR1000 and my question is ping supported for feo filtering on console? I have set on and when I’m on the geo filtering screen it shows the people and servers. It gives me the option to allo...
Netduma-Fraser
Jan 19, 2023NetDuma Partner
Ping Assist is an assist feature of the Geo-Filter so it's not a hard limit, if you're wanting servers under a specific value I would suggest using the radius instead with Ping Assist to 0 to ensure you get low ping servers.
Humboldtk20
Ok makes sense. Ok so the last question is are all games support for geo filtering? I only play PUBG and that’s the game where it’s difficult to get low ping servers.
- Netduma-FraserJan 19, 2023NetDuma PartnerPretty much, some will work straight away, some may need some servers to be allowed, others we'd need to work on it specifically and very few are unable to be filtered at all. Try the radius only and see if that works better for you.
- Humboldtk20Jan 19, 2023AspirantOk. So I’m in California and the low ping servers I found via the ping heat tap says there on the east coast. What do you recommend as far as radius?
- Netduma-FraserJan 19, 2023NetDuma PartnerMove your home location there and then use 1000km radius and see how you get on
