Alewi
May 13, 2022Apprentice
Geo-filter question! Xr700
Greetings netgear community, I am playing efootball 2022 and they claimed, that they are using dedicated server now for matchmaking, unlike the old Pro evolution soccer versions wich use peer 2 peer ...
- May 13, 2022Probably not lying, they may be keeping P2P open if you're unable to connect to a server for some reason e.g. if you're blocking it with the Geo-Filter
Alewi
Hi fraser,
Thanks for the fast feedback as usual of you.
Every time I got connected to a different player, I got a deferent domain.
Netduma-Fraser
May 13, 2022NetDuma Partner
Could you provide one for an example? It may be different servers you're connecting to or simply it may be that they have not yet rolled out dedicated servers to all regions
- AlewiMay 13, 2022ApprenticeI thought that i might be connecting to a different servers, but as I played more, there are a lot of domains. I took screen shot for one exampleo will attach it. The ping to the person i play against is 4ms( there is no chance that i will get that low ping to a server! They said that they already using the client server for matchmaking ( i will attach a screen shot for that)
- Netduma-FraserMay 13, 2022NetDuma PartnerThank you for that, I converted the ID to an IP and looked that up, it is a peer connection in Germany so definitely not a server!
