Alewi
May 13, 2022Apprentice
Geo-filter question! Xr700
Greetings netgear community, I am playing efootball 2022 and they claimed, that they are using dedicated server now for matchmaking, unlike the old Pro evolution soccer versions wich use peer 2 peer ...
- May 13, 2022Probably not lying, they may be keeping P2P open if you're unable to connect to a server for some reason e.g. if you're blocking it with the Geo-Filter
Alewi
I thought that i might be connecting to a different servers, but as I played more, there are a lot of domains. I took screen shot for one exampleo will attach it. The ping to the person i play against is 4ms( there is no chance that i will get that low ping to a server! They said that they already using the client server for matchmaking ( i will attach a screen shot for that)
Alewi
- Netduma-FraserMay 13, 2022NetDuma PartnerThank you for that, I converted the ID to an IP and looked that up, it is a peer connection in Germany so definitely not a server!
- AlewiMay 13, 2022ApprenticeJust to be sure... is client- server system the same as dedicated server? In other word, in warzone they use dedicated server, so is it client server system? I know it is the same, just asking to be sure.
- Netduma-FraserMay 13, 2022NetDuma PartnerYes that's right - you (the client) connects to the server
