Alewi
May 13, 2022Apprentice
Geo-filter question! Xr700
Greetings netgear community, I am playing efootball 2022 and they claimed, that they are using dedicated server now for matchmaking, unlike the old Pro evolution soccer versions wich use peer 2 peer ...
- May 13, 2022Probably not lying, they may be keeping P2P open if you're unable to connect to a server for some reason e.g. if you're blocking it with the Geo-Filter
Netduma-Fraser
May 13, 2022NetDuma Partner
Thank you for that, I converted the ID to an IP and looked that up, it is a peer connection in Germany so definitely not a server!
Alewi
Just to be sure... is client- server system the same as dedicated server? In other word, in warzone they use dedicated server, so is it client server system? I know it is the same, just asking to be sure.
- Netduma-FraserMay 13, 2022NetDuma PartnerYes that's right - you (the client) connects to the server
- AlewiMay 13, 2022ApprenticeIn other words, they are lying! I will contact their support team and see what they will answer! If you are interested, keep this thread open and I will update it with their answer.
- Netduma-FraserMay 13, 2022NetDuma PartnerProbably not lying, they may be keeping P2P open if you're unable to connect to a server for some reason e.g. if you're blocking it with the Geo-Filter
- AlewiMay 31, 2022ApprenticeAfter a lot of back and forth and a lot of pure nonsense of konami support team, they said...yes they are using dedicated server! Which i can't believe it, cuz that what I experience and see.
- Netduma-FraserMay 31, 2022NetDuma PartnerProvide another ID when you're playing and I can check to see if it is a server
- AlewiMay 31, 2022ApprenticeI can do that on the second of June, cuz they are doing a massive server maintenance from 29/05 until the 02/06! ( typical konami).
But more likely as you said... they are using kind of mixed matchmaking system with dedicated and peer to peer, but they don't announce it. In case they really use dedicated servers now, would netduma be able to add the servers to the ping heat map in os3.0? - Netduma-FraserMay 31, 2022NetDuma PartnerYes we could definitely do that!
