Alewi
May 13, 2022Apprentice
Geo-filter question! Xr700
Greetings netgear community, I am playing efootball 2022 and they claimed, that they are using dedicated server now for matchmaking, unlike the old Pro evolution soccer versions wich use peer 2 peer ...
- May 13, 2022Probably not lying, they may be keeping P2P open if you're unable to connect to a server for some reason e.g. if you're blocking it with the Geo-Filter
Alewi
In other words, they are lying! I will contact their support team and see what they will answer! If you are interested, keep this thread open and I will update it with their answer.
Netduma-Fraser
May 13, 2022NetDuma Partner
