Ketch_xxii's avatar
Ketch_xxii
Initiate
May 09, 2020
Geo filter stopped populating servers
Hello,   I hope this goes to the right place, but my router was working fine and i had an issue where every time it rebooted it would reset to factory defaults. After months of racking my brain i t...
  • Netduma-Fraser's avatar
    May 12, 2020
    Please follow these steps and see if that resolves it:
    1. Hard turn off the console - hold the power button until it turns off (it should beep twice)
    2. Remove the device from the Geo-Filter
    3. Flush the cloud from the Geo-Filter Map options
    4. Re-add the device to the Geo-Filter
    5. Make any Geo-Filter changes you need to
    6. Boot up the console and game
    If it still isn't working, have you made any port changes for the PS4?
