Rick6922
Dec 11, 2018Luminary
geo filter
is the top 2 bars in the antibuffer bloat what im limiting the other devices too or is it what Im getting?I bought the xr700 a couple days ago to use with xbox 1x and black ops 4.I set up Qos and Geo...
Netduma_Jack
Dec 12, 2018NetDuma Partner
Hi Rick,
Those two Anti-Bufferbloat bars set how much your total bandwidth will be limited to. For example, if you had 100mbps total and set it to 70%, you will now have 70mpbs. This ensures there's always room for low latency applications like games.
Here are the best guides for setting up QoS and the Geo-Filter on your DumaOS powered router:
http://support.netduma.com/support/solutions/articles/16000077073-dumaos-optimal-settings-guide-qos
Rick6922
Dec 12, 2018Luminary
Thanks for the reply. I want 70% of my internet going to my xbox and 30% going to other devices. So if I set the sliders to 70%. is that the Xbox or every thing total? on the anti buffer bloat page i have 70% on the the sliders. then down in Bandwidth allocation -download Ive got the xbox1 set at 70%. when I have that enabled I get in game lag.if i turn the anti buffer bloat off i dont have the lag which leads me to belive Ive got the setting wrong. Im a pretty serious gamer and the only reson I bought the big money router is for anti buffer bloat and geo-filter.what should i have my setting set at?
- Netduma-FraserDec 12, 2018NetDuma PartnerAnti-Bufferbloat applies to everything. If it's better off then it sounds like it's not configured correctly. Put the speeds you pay for in Anti-Bufferbloat's options menu. 70% for both download & upload sliders. Change Anti-Bufferbloat to apply 'Always'. You can leave Bandwidth Allocation default most likely, just ensure share excess is ticket for Bandwidth Allocation on both download/upload. Gaming barely uses any bandwidth so giving it 70% is overkill. Then remove any manual rules from Traffic Prioritization and leave DumaOS Classified Games enabled. Geo-Filter place your radius where you live and use the CoD profile.
- Rick6922Dec 12, 2018Luminary
did that and so far so good, thanks a bunch.:smileyhappy:
