Rick6922
Dec 11, 2018Luminary
geo filter
is the top 2 bars in the antibuffer bloat what im limiting the other devices too or is it what Im getting?I bought the xr700 a couple days ago to use with xbox 1x and black ops 4.I set up Qos and Geo...
Rick6922
Dec 12, 2018Luminary
Thanks for the reply. I want 70% of my internet going to my xbox and 30% going to other devices. So if I set the sliders to 70%. is that the Xbox or every thing total? on the anti buffer bloat page i have 70% on the the sliders. then down in Bandwidth allocation -download Ive got the xbox1 set at 70%. when I have that enabled I get in game lag.if i turn the anti buffer bloat off i dont have the lag which leads me to belive Ive got the setting wrong. Im a pretty serious gamer and the only reson I bought the big money router is for anti buffer bloat and geo-filter.what should i have my setting set at?
Netduma-Fraser
Dec 12, 2018NetDuma Partner
Anti-Bufferbloat applies to everything. If it's better off then it sounds like it's not configured correctly. Put the speeds you pay for in Anti-Bufferbloat's options menu. 70% for both download & upload sliders. Change Anti-Bufferbloat to apply 'Always'. You can leave Bandwidth Allocation default most likely, just ensure share excess is ticket for Bandwidth Allocation on both download/upload. Gaming barely uses any bandwidth so giving it 70% is overkill. Then remove any manual rules from Traffic Prioritization and leave DumaOS Classified Games enabled. Geo-Filter place your radius where you live and use the CoD profile.
- Rick6922Dec 12, 2018Luminary
did that and so far so good, thanks a bunch.:smileyhappy:
