Rick6922
Dec 11, 2018Luminary
geo filter
is the top 2 bars in the antibuffer bloat what im limiting the other devices too or is it what Im getting?I bought the xr700 a couple days ago to use with xbox 1x and black ops 4.I set up Qos and Geo...
Netduma_Jack
Dec 12, 2018NetDuma Partner
Hi Rick,
Those two Anti-Bufferbloat bars set how much your total bandwidth will be limited to. For example, if you had 100mbps total and set it to 70%, you will now have 70mpbs. This ensures there's always room for low latency applications like games.
Here are the best guides for setting up QoS and the Geo-Filter on your DumaOS powered router:
http://support.netduma.com/support/solutions/articles/16000077073-dumaos-optimal-settings-guide-qos
Chanharr
Dec 12, 2018Aspirant
Hi Jack,
The NetdumaOS instructions for the open beta, is that firmware image compatible with the Netgear XR500? I got access to the Open Beta, but the file download came in as a .sig and is not a .img
Thanks!
Thanks!
- Netduma_JackDec 13, 2018NetDuma Partner
Hi there - no that firmware is just for the Netduma R1. You will not be able to install it on th XR500.
The next XR500 firmware is going through internal testing at NETGEAR (the final step before release), so it should hopefully be out there soon.
