Mattv123's avatar
Mattv123
Follower
May 20, 2020
Geo filter
Does anyone know what nil does or means? Under options in the geo filter, under flush cloud I have a “nil” with checkbox next to it and options of 2.5-5-8-10-15. Then I have a nil and a slider from 0-200. Nothing happens when I adjust them and there literally nothing on the internet that talks about it lol anyone have a clue of what that is or does??
1 Reply
  • That's an issue that we're aware of and will be fixing, it is aesthetic so won't affect performance. The first is Zoom factor so how much it zooms in when you use the zoom feature. The second is Ping Assist so setting the upper limit for Ping Assist to filter by.
