Harryq
Jul 29, 2022Initiate
Geo filter
I can't use geo filter because it says it's not able to connect to the cloud. It has a tutorial image over the map with no way to close it out. Everything else seems to be working.
Jul 29, 2022Guru - Experienced User
Which XR router do you have?
- HarryqJul 29, 2022InitiateIt seems to be working now. Not sure why, all I did was shut the laptop down for a couple of hours and then logged back on to it. Thank you for replying to me though.
