vrspectre's avatar
vrspectre
Apprentice
Aug 08, 2019
Geo-filtering for Warframe
I've got an XR500 and want to try out the geo-filtering feature. When I try to add my PS4 to the it takes me to a geo-filtering selector screen. Warframe is not an option. Is there a different one I should select that will work?
  • In the Device Manager, make sure that your PS4 is set to the PlayStation device type.
    Then remove the device from the Geo-Filter and add it again. You shouldn't be asked to choose a game this time.
