hotpeppershrmp
Apr 04, 2021Aspirant
Geofilter doesn't work at all in Street Fighter on Steam
In the router settings, I set my PC to Console, and I left all the options for tighter restrictions turned on.
However, visually, users outside the geofilter map continue to connect,
It even matche...
- Apr 06, 2021
The reason you're connecting to players outside of your radius is because you have ping assist set to 40. Could you please try setting ping assist to 0, reboot the game and try again. You should now only be matched with players inside your search radius.
hotpeppershrmp
Apr 06, 2021Aspirant
So, in what situations is the Ping Assist feature most effective?
Are there any recommended usage environments?
Netduma-Fraser
Apr 06, 2021NetDuma Partner
Actually the main reason likely alongside ping assist is that you have fast search enabled - this can ignore Ping Assist to get you a faster game. Turn this off first, then try, if it continues lower Ping Assist to 30/35.
