blaisual
May 09, 2021Tutor
geofilter fail xr500 destiny
i have the firmware xr500 v2.3.2.114 but the geofilter does not working on the game destiny 2,does someone have a solution or know howto fix it. have already tried a lot and tried but nothing worked ...
Netduma-Liam
May 10, 2021NetDuma Partner
We have recently pushed an update for Destiny so you should be able to filter by servers now. We are aware that there appear to be a couple of authentication servers that can still be blocked so you may need to manually allow any 'blocked' connections that appear in Geo-filter when you try to find a game. Once we've pushed a new cloud update, you shouldn't need to do this.
Also, the error you're seeing in Ping Heatmap is normal, it will have successfully sync'd with the cloud, it just threw an error becaues it took a bit longer than it was expecting.
- DunazMay 10, 2021GuideCome faccio a capire se il mio xr500 blocca i server, sembra che continua a ignorare geofilter, guida i alla soluzione grazie
- Netduma-LiamMay 11, 2021NetDuma Partner
Abbiamo una guida nella nostra knowledge base che dovrebbe aiutarti in questo:
http://support.netduma.com/support/solutions/articles/16000077072-dumaos-optimal-settings-guide-geo-filter
Facci sapere se hai ulteriori domande!- DunazMay 11, 2021Guide
Great job guys, the router filters destiny perfectly thanks
- MalverMay 18, 2021Aspirant
Liam, ese par de servidores a los que haces referencia permiten bloquear jugadores fuera de rango en destiny 2 como antes de la actualización? donde estan situados estos servidores para probar el geofiltro?
Muchas gracias.
- Netduma-LiamMay 18, 2021NetDuma Partner
Ya no creo que puedas bloquear a jugadores específicos con DumaOS solo, ya que Destiny ahora se ha movido al emparejamiento basado en servidor y no de igual a igual.
no entiendo eso...emparejamiento de igual a igual.
que yo sepa destiny2 nos conecta a un servidor a todos los jugadores y luego el propio servidor busca jugadores con un mismo nivel para emparejarlos..
eso lo an cambiado?
