blaisual
May 09, 2021Tutor
geofilter fail xr500 destiny
i have the firmware xr500 v2.3.2.114 but the geofilter does not working on the game destiny 2,does someone have a solution or know howto fix it. have already tried a lot and tried but nothing worked ...
Netduma-Liam
May 10, 2021NetDuma Partner
We have recently pushed an update for Destiny so you should be able to filter by servers now. We are aware that there appear to be a couple of authentication servers that can still be blocked so you may need to manually allow any 'blocked' connections that appear in Geo-filter when you try to find a game. Once we've pushed a new cloud update, you shouldn't need to do this.
Also, the error you're seeing in Ping Heatmap is normal, it will have successfully sync'd with the cloud, it just threw an error becaues it took a bit longer than it was expecting.
Dunaz
May 10, 2021Guide
Come faccio a capire se il mio xr500 blocca i server, sembra che continua a ignorare geofilter, guida i alla soluzione grazie
