GLitchGlenn
Aug 29, 2019Initiate
Geofilter not working on pc
Good Day. Coming from ps4 to pc since a week. I was hoping that my xr500 would work the same way like i had it on my Ps4 with setting regions to block out other countries that are known for pooor co...
Netduma-Fraser
Aug 29, 2019NetDuma Partner
In the Device Manager change the Device Type of the PC to an Xbox or PlayStation then remove the device from the Geo-Filter and re-add it. Does it work then?
GLitchGlenn
yes it did. thank you very much for great support. had no idea i could do that. many many thx
