Cayde-6
Apr 16, 2021Tutor
Geofilter not working
I don't know what happened, it worked perfectly until now. I've tried everything: Changed the ping position Removed and added again the devices Updated to the latest version (V2.3.2.114) and...
Netduma-Fraser
Apr 16, 2021NetDuma Partner
What's the problem exactly that you're unable to filter games? What game are you trying to play? You're not able to allow yourself as you don't appear on the Geo-Filter
Cayde-6
Apr 16, 2021Tutor
Destiny 2 but i've recentely saw on another thread that you guys are planning to release a workaround maybe next week.
I love what you guys are doing, i appreciate a lot.
- Netduma-FraserApr 17, 2021NetDuma PartnerYes Destiny has changed their matchmaking system so it no longer works like it did. Not a workaround no but a cloud update so you should be able to filter servers like most games.
- TimboSlice1967Oct 09, 2021AspirantHave same issues with COD, live in uk.. always playing against french, german or spanish players who have massive advantages.. especially french. Changed my location to central USA still getting same lobbies! Playing on PS5, have super fast broadband, wired connections… paid s fortune for this set up and just cannot get it to work for me. Running latest software and everything…. Doesn’t matter what time i play, i get shot first, QOS is just as bad, have everything biased towards PS5, daughter streams from YouTube and I’m dead!
- Netduma-FraserOct 09, 2021NetDuma PartnerYou can't influence what players join your games, just the server you connect to. It sounds like you probably have Ping Assist enabled, set that to 0 and you can force servers properly. Gaming doesn't require much bandwidth so using Bandwidth Allocation won't help - Anti-Bufferbloat and Traffic Prioritization will prevent you from lagging when other devices are being used.
