Cayde-6
Apr 16, 2021Tutor
Geofilter not working
I don't know what happened, it worked perfectly until now. I've tried everything: Changed the ping position Removed and added again the devices Updated to the latest version (V2.3.2.114) and...
Netduma-Fraser
Oct 09, 2021NetDuma Partner
You can't influence what players join your games, just the server you connect to. It sounds like you probably have Ping Assist enabled, set that to 0 and you can force servers properly. Gaming doesn't require much bandwidth so using Bandwidth Allocation won't help - Anti-Bufferbloat and Traffic Prioritization will prevent you from lagging when other devices are being used.
TimboSlice1967
Oct 09, 2021Aspirant
Bandwidth allocation is set to 64 on download, 33 on upload to my ps5. Congestion control is 70 and 51, Ping assist is off, Filtering on at 1000km, cant find bufferbloat...
- Netduma-FraserOct 09, 2021NetDuma PartnerAnti-Bufferbloat was the old name for Congestion Control, what do you have set for Traffic Prioritization? What are your bandwidth speeds? What is the model of the modem the XR is connected to? Are ALL devices connected to the XR? Provide a screenshot of the Geo-Filter showing you getting a game in EU when set for the US and we can see what is happening
