heroxoot
Nov 27, 2018Apprentice
Geofilter problems
Im having problems with my GEOFILTER. I can use it if I set my PC to Console but otherwise it wont populate a list. If I do that it wont let my PC connect to some websites or discord servers outside ...
Netduma_Jack
Nov 28, 2018NetDuma Partner
Hi there - the Unreal Engine will not work for those games unforunately. So the workaround is exactly as you have done (set your PC as a console).
I'm afraid there's no easy solution to this - the best thing to do is leave your device in Spectating mode most of the time. But when you go to search for a game, just switch ti back to Filtering Mode. It won't block any active connection (e.g. an open website or a chat service you have going) and it will then filter for the game.
heroxoot
Nov 28, 2018Apprentice
Alright but how do I get it to just allow all connections like this? When I set it up as I have it, it will block stuff outside the radius. It blocked a discord server on me that was right on the outer edge and for a hot 10 minutes I was really confused what was happening. Do I turn off strict mode? Realistically I just wanna see the ping of the players around me and block people outside NA from playing me.
- Netduma_JackNov 29, 2018NetDuma Partner
When you are in Spectating Mode, nothing will be blocked. So only when you search for a game and need the filter to kick in should you switch to Filtering Mode. Then go back to Spectating Mode once you have found a match within your distance range. Does that make sense?
This approach will ensure nothing is blocked other than other players, because you will only be in blocking (filtering) when you are searching for a game.
- heroxootNov 29, 2018Apprentice
Its working now but before it was still blocking in spectator. Maybe rebooting my PC helped. My only problem now is when someone disconnects from me, they stay populated on my map when I play Tekken. In SFV they disappear once they stop connecting. Makes it hard to figure out who I'm pinging.
