heroxoot
Nov 27, 2018Apprentice
Geofilter problems
Im having problems with my GEOFILTER. I can use it if I set my PC to Console but otherwise it wont populate a list. If I do that it wont let my PC connect to some websites or discord servers outside ...
heroxoot
Nov 28, 2018Apprentice
Alright but how do I get it to just allow all connections like this? When I set it up as I have it, it will block stuff outside the radius. It blocked a discord server on me that was right on the outer edge and for a hot 10 minutes I was really confused what was happening. Do I turn off strict mode? Realistically I just wanna see the ping of the players around me and block people outside NA from playing me.
Netduma_Jack
Nov 29, 2018NetDuma Partner
When you are in Spectating Mode, nothing will be blocked. So only when you search for a game and need the filter to kick in should you switch to Filtering Mode. Then go back to Spectating Mode once you have found a match within your distance range. Does that make sense?
- Netduma_JackNov 29, 2018NetDuma Partner
This approach will ensure nothing is blocked other than other players, because you will only be in blocking (filtering) when you are searching for a game.
- heroxootNov 29, 2018Apprentice
Its working now but before it was still blocking in spectator. Maybe rebooting my PC helped. My only problem now is when someone disconnects from me, they stay populated on my map when I play Tekken. In SFV they disappear once they stop connecting. Makes it hard to figure out who I'm pinging.
Yea I think my only issues now is slow pinging and people stick on the map longer than I'd like making it hard to determine who is the connection.
