heroxoot
Nov 27, 2018Apprentice
Geofilter problems
Im having problems with my GEOFILTER. I can use it if I set my PC to Console but otherwise it wont populate a list. If I do that it wont let my PC connect to some websites or discord servers outside ...
heroxoot
Nov 29, 2018Apprentice
They are indeed players. They do go away after a while. Most of them are easily identified as players with domains that say stuff like FiOS and Comcast. They just stick around longer for some reason in tekken compared to other games.
Netduma-Fraser
Nov 29, 2018NetDuma Partner
It must be to do with how the game processes the match after it ends. If it's just that game then thats fine, the Geo-Filter is just reporting the connections that are happening
