RaidenOsamu
Oct 12, 2022Guide
Geofilter The rapp is not loaded yet.
The geofilter does not load at all for me and I get this error message. Same as for ping heatmap.
Netduma-Liam
Oct 13, 2022NetDuma Partner
Could you please clarify exactly which router you're using and which firmware version it's currently running?
Could you also please let us know which browser are you accessing the interface from?
RaidenOsamu
Oct 13, 2022Guide
Thanks for replying! I was able to get the geofilter to work after reseting the router and installing the firmware again! A new issue that I have now is since I have fiber for my PS5 I get 800 to 900 Mbps through the modem supplied by the ISP but after connecting to the router I get 500 Mbps for download speeds.
- Netduma-FraserOct 13, 2022NetDuma PartnerAre you testing the speed on the console or on a PC? The console tests can be inaccurate - if you're getting the speed on a PC then the console won't be limited.
- RaidenOsamuOct 13, 2022Guide
I did the test on console and yesterday when I did a speedtest on the PC it gave me an even lower number of somewhere around 50 Mbps for upload and download haha. I got fiber optic last month and signed up for the 5000 Mbps plan since I have smart home devices as well at my home.
- Netduma-FraserOct 13, 2022NetDuma PartnerHave a look at this guide and it should boost your speeds http://support.netduma.com/en/support/solutions/articles/16000076586-dumaos-optimal-settings-guide-maximum-bandwidth-speeds
