RaidenOsamu
Oct 12, 2022Guide
Geofilter The rapp is not loaded yet.
The geofilter does not load at all for me and I get this error message. Same as for ping heatmap.
RaidenOsamu
Oct 13, 2022Guide
Thanks for replying! I was able to get the geofilter to work after reseting the router and installing the firmware again! A new issue that I have now is since I have fiber for my PS5 I get 800 to 900 Mbps through the modem supplied by the ISP but after connecting to the router I get 500 Mbps for download speeds.
Netduma-Fraser
Oct 13, 2022NetDuma Partner
Are you testing the speed on the console or on a PC? The console tests can be inaccurate - if you're getting the speed on a PC then the console won't be limited.
- RaidenOsamuOct 13, 2022Guide
I did the test on console and yesterday when I did a speedtest on the PC it gave me an even lower number of somewhere around 50 Mbps for upload and download haha. I got fiber optic last month and signed up for the 5000 Mbps plan since I have smart home devices as well at my home.
- Netduma-FraserOct 13, 2022NetDuma PartnerHave a look at this guide and it should boost your speeds http://support.netduma.com/en/support/solutions/articles/16000076586-dumaos-optimal-settings-guide-maximum-bandwidth-speeds
Thank you 🙂
- FURRYe38Oct 13, 2022Guru - Experienced User
"5000Mbps"? or 500Mpbs?
Sorry about that. A typo on my end. It is 5000 Mbps. Thank you for your help 🙂
