ConcreteSlayr
Jul 08, 2019Tutor
Geofilter XR500
When i try to select a device in my geofilter it tells me that filters are overlapping. I dont know of anything ive done except forwarded ports.ive deleted my device from QOS. Any Advice?
Netduma-Fraser
Jul 09, 2019NetDuma Partner
When you try to add the device do you already have that same device added on the Geo-Filter?
- ConcreteSlayrJul 11, 2019Tutor
Im too embarressed to answer that.LOL
- Netduma-FraserJul 13, 2019NetDuma PartnerHaha no worries, easy mistake to make! Glad it was a simple solution!
