carchd
Mar 08, 2018Aspirant
Geofiltering Blank
Hi, I am currently running 2.2.0.4. When I matchmake in Destiny 2 (PC) I am showing nothing on my geofiltering page, completely blank. I have not tried any other games. Because D2 is peer to peer I f...
Netduma_Jack
Mar 09, 2018NetDuma Partner
Hi - Destiny 2 runs on a hybrid system, sometimes using Dedicated Servers and sometimes Peer to Peer. Do you ever see icons appearing on the map, or is it blank all the time? Please try the steps below:
1. Go to Device Manager
2. Click on your gaming PC on the network map
3. On the device details panel that opens, change the device type from PC to PS4
4. Click Save
5. Go to Geo-filter
6. Delete your PC from the Device panel at the top, and then re-add it
7. This time it won’t ask for a service, and will instead be added automatically with ‘console’ as the service
8. You then MUST change the mode to spectating mode. Do not leave it in filtering mode as it will prevent you from joining games and using the Internet
9. Now try playing Destiny 2. Does the server appear this time?
