hamsot
Mar 03, 2018Guide
Getting "400 Bad Request" on VLAN tagging
Hello, I am trying to setup my XR500 to connect to my CentryLink fiber. The internet connection uses PPPoE and VLAN Tagging 201. When I tried to edit the existing or create a new VLAN tag group, I go...
hamsot
Mar 04, 2018Guide
Hi Fraser,
The wizard didn't get very far to me so I used manual settings instead. I tried to change it manually in Settings > Advanced setting and it gave me the 400 Bad Request error.
I will call Tech Support and see what they can do.
Thank you for your help.
Netduma-Fraser
Mar 04, 2018NetDuma Partner
Netgear Tech Support should be able to help with that! Do update us to let us know how you get on.
- hamsotMar 18, 2018Guide
I spent two hours with Netgear Tech Support. My hats off to them for being so patient with me. However, the ticket is still opened and they are still trying to resolve the issue.
