Ahnubys-'s avatar
Ahnubys-
Gig wifi normal speeds wired speeds slow
Hi there my xr1000 with gigabit internet I'm getting around 600-800 mbps over wifi on my smartphones but over a wired connection to ps5 I'm only getting around 150-200 mbps previous to this router I was using a rental from cox with 500 mbps internet and was receiving 300-400 mbps wired and wifi.
  • Sorry to hear this!
    Have you tried a different ethernet cable to the PS5?
    Do you have QoS configured? If so, do you see an increase in speeds if you disable this from the three-line menu in Congestion Control?
    • Ahnubys-'s avatar
      Ahnubys-
      I've tried a several cables cat6 and cat5e also have had qos on and off speeds change a bit when off but still roughly 200 mbps either way I've been leaving it off because my phones get over 600 with it off on they are around 100 when I try wifi on the ps5 I get a strict nat type (type 3) and only get about 160 mbps to maybe 200 mbps
      • Netduma-Liam's avatar
        Netduma-Liam
        NetDuma Partner
        Is the PS5 the only device that's getting low speeds from the XR or are all wired devices experiencing this?
        What is the exact make and model of the modem the XR is connected to?
