Ahnubys-
Jul 18, 2021Aspirant
Gig wifi normal speeds wired speeds slow
Hi there my xr1000 with gigabit internet I'm getting around 600-800 mbps over wifi on my smartphones but over a wired connection to ps5 I'm only getting around 150-200 mbps previous to this router I w...
Netduma-Liam
Jul 19, 2021NetDuma Partner
Is the PS5 the only device that's getting low speeds from the XR or are all wired devices experiencing this?
What is the exact make and model of the modem the XR is connected to?
Ahnubys-
Jul 19, 2021Aspirant
The xr is connected to a cm1000v2 and I have tested my ps4 and ps5 both are getting roughly same speeds I can't test a pc because the only thing I have is an old laptop that can recieve 100 mbps
- Netduma-LiamJul 19, 2021NetDuma Partner
Right OK thanks for checking that, I just wanted to know if it was a pure modem or a modem/router, but that answers that.
Could you please go to the WAN settings of the XR and change NAT filtering to Open? Then retest the consoles and see if you have an open NAT type and if the speeds are better.
