Mustang1313
Sep 20, 2024Aspirant
Gigabit wifi speeds halved on XR1000
I'm sure that this topic gets touched on a couple of times a month at this point, but I cannot find a working solution to this issue. I just moved to a new house and we upgraded to gigabit download s...
Mustang1313
I'm testing using the downloaded speed test.net app on my computer and phone located maybe 4 feet from the router. Getting the full speed straight from the modem, yes.
Firmware: XR1000V2 1.1.0.16_2.1.25
Modem: Spectrum DOCSIS 3.1 eMTA
I am using CAT6 cables and set the channels to the ones you recommended.
So far it's still in the 400 range. Please let me know if you have any other ideas!
Mustang1313
I should clarify: Ethernet speed has improved to 900
5G signal has not improved at all.
I've checked wifi and there is no interfering signal in my area.
- Netduma-FraserSep 21, 2024NetDuma PartnerDo you have Smart Connect enabled or disabled?
Ensure the router is in an elevated position - not on a metal surface
Ensure there aren't any electrical / wireless devices e.g headphones etc within close proximity ~3 feet if possible
Set the antennae to this position _ | | _
Then see if that improves it. What is the device you're testing the WiFi speeds on also?
