Raysir1
Apr 02, 2021Tutor
GoDaddy email is not working since router install xr1000
My router isn't listed so I had to pick the model 700 but mine is an XR1000 ...After installing the new router my godaddy email account cannot connect. I've worked w/godaddy cust. serv. but they don'...
Raysir1
Apr 02, 2021Tutor
I let the router do the setup, I called my Int. provider after that and he made sure I was running DCHP...and that was it, router works great for all things besides being able to log in to the godaddy secureserver. ARMOR-to my knowledge is on, I've received a couple emails and texts from it but no issues.
Netduma-Fraser
Apr 02, 2021NetDuma Partner
Could you try disabling Armor, then reboot the router from the interface and see if it works please?
