Raysir1
Apr 02, 2021Tutor
GoDaddy email is not working since router install xr1000
My router isn't listed so I had to pick the model 700 but mine is an XR1000 ...After installing the new router my godaddy email account cannot connect. I've worked w/godaddy cust. serv. but they don'...
Netduma-Fraser
Apr 02, 2021NetDuma Partner
Could you try disabling Armor, then reboot the router from the interface and see if it works please?
Raysir1
Apr 02, 2021Tutor
yep that was it, ARMOR was stopping the godaddy email.secureserver.net from getting through. So is there a fix for this? Or just cancel ARMOR altogether?
Thanks for the help!
- Netduma-FraserApr 02, 2021NetDuma PartnerThat could be something for Netgear/Armor to fix, I don't think that is anything on our side. TimChang could you take a look please?
