admael
May 24, 2018Aspirant
Guest network no internet access
My devices are not able to access the internet while connected to the guest network. The same devices work fine when connected to the main network
Any suggestions?
Netduma-Fraser
May 25, 2018NetDuma Partner
Are the guest devices showing as blocked on the Device Manager?
admael
May 26, 2018Aspirant
No, it does not show up as blocked. Still having an issue with this
- Netduma_JackMay 26, 2018NetDuma Partner
I recommend you give NETGEAR support a call as you'll get a quicker reply from them than on here:
