Thiscompanysux
Jan 11, 2022Aspirant
HALF SPEED ON XR700
My XR700 router is blocking internet speeds less than half of what I am paying my ISP for (350 mb down actual vs 1000 mb down paid for) with the following specs: Sparklight 1GB internet Arris SB82...
Jan 11, 2022Guru - Experienced User
are you only testing using the built in speedtest?
Try testing it using the speedtest site.
And try different servers on the speedtest site.
Have you tried manually setting up a speed on the xr700?
- ThiscompanysuxJan 11, 2022Aspirant
Running speed test through separate test site and through ISP provider's site. I have manually set the internet speed without any change.
- Netduma-FraserJan 11, 2022NetDuma PartnerHow did you disable QoS exactly? If you didn't do it from the Anti-Bufferbloat/Congestion Control 3 line option menu in the top left of the panel then please do so and do a test again. Did you try the beta firmware?
