Thiscompanysux
Jan 11, 2022Aspirant
HALF SPEED ON XR700
My XR700 router is blocking internet speeds less than half of what I am paying my ISP for (350 mb down actual vs 1000 mb down paid for) with the following specs: Sparklight 1GB internet Arris SB82...
Thiscompanysux
Running speed test through separate test site and through ISP provider's site. I have manually set the internet speed without any change.
Netduma-Fraser
Jan 11, 2022NetDuma Partner
How did you disable QoS exactly? If you didn't do it from the Anti-Bufferbloat/Congestion Control 3 line option menu in the top left of the panel then please do so and do a test again. Did you try the beta firmware?
